2f head installation
Discussion in '40- & 55-Series Tech' started by Webster, Aug 8, 2003.
  1. Webster
    Webster
    236
    Feb 20, 2002
    I seem to have a chronic head gasket problem, wondering if my installation procedure could be contributing.
    Anyone care to share their tried and true installation procedure?
    How about what you have found to work on adjusting the valves?
    Thansk!
  2. Pinion
    Pinion
    1,124
    1
    Jun 16, 2003
    Milford, Mass
    I torque according to the manual. Use which ever thread locker they tell you to.
    I set valve lash as it is suggested in the manual.
    These two things are pretty straight forward.
    Have you had head problems before?
    If so, have you had the head decked?
  3. Webster
    Webster
    236
    Feb 20, 2002
    I have both manuals (Chiltons, Haynes) and they both vary. Neither mentions a threadlocker. One suggests valve adjusting while running and the other while cold and not running.
    Is there a need to retorque the head bolts after running a while?
  4. Webster
    Webster
    236
    Feb 20, 2002
    This is a rebuilt head just a year old.
  5. Pinion
    Pinion
    1,124
    1
    Jun 16, 2003
    Milford, Mass
    Get the engine up to running temp and then set the motor to TDC. Do 1/2 the valves, and then rotate 180*, then do the other ones the manual tells you to. Dont set it while running, its not necessary.
    The threadlocker for the head will let you get the correct torque and wont back out so you wont have to re tighten it. Tighten 'em down and let it set up, just make sure you dont use the super heavy duty stuff. Some high temp stuff works best. I also use a thread cutter to clean out all the crap that can collect down there.
  6. Pinion
    Pinion
    1,124
    1
    Jun 16, 2003
    Milford, Mass
    [quote author=Webster link=board=1;threadid=4192;start=0#msg31070 date=1060363470]
    [/quote]
    Was it decked though? It isnt a normal part of the process. Some shops will just rebuild them and ask if you want it decked. If it isnt totally straight/flat, you will have gasket problems.
  7. petescoffee
    petescoffee
    1,824
    19
    Dec 29, 2002
    Walnut Creek, CA
    Check the head for flatness. Just because it was redone doesn't mean it is flat. Also Check the block for flatness. When I rebuilt my 2f I had the block decked as it was out. Do not use A file to flatten out the deck on the head or block.
    Also, very important, Retorque the head after start up and again after 500 miles. Do a search on the lcml for Mark's W. comments regarding this. I spoke to another LC Guru and he said the same thing and not retorquing is one of the most common reasons he see's blown head gaskets from people that do it themselves, like me.
    good luck.
  8. Chef
    Chef
    1,972
    6
    Jan 24, 2003
    Columbia, MO
    It should be standard procedure to re-torque cylinder heads after 2 or 3 heat cycles, and again at 550, and 1000 miles. This may sound excessive, but SAE and other engineering studies have shown that fasteners can lose as much as 10% of their torque value just sitting there for 10-15 minutes, and even more than that after several heat cycles. It is a good idea to check both the block deck and head for true...
  9. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    Retorque. Makes sense to me, I mean, I have to do it to my race bikes. All the retorques in the world won't do any good for a warped head though.
  10. dd113
    dd113
    2,923
    1
    Jun 13, 2003
    Yes, you should torque the bolts again after a few cycles but I never seem to get around to it. All my motors are fine. One item that i have found healpul is a compression washer. I use them on all old heads. Costs around a $1 a bolt.Allows you to torque it down then it stays there. Also makes up for any slop in the head if it as been decked mutiple times.
  11. techninja
    techninja
    13
    Mar 3, 2004
    Do you retorque the head when it is hot?
    This is what Man-A-Fre says they are going to do when they adjust the valves...head is still original w/199k miles.
    Seems weird to me, but the last rebuild of a car I did (which involved r/r a head) was a 1957 Borgward, and the only other one was a CB 500 four Honda...
  12. matt.mcinnes
    matt.mcinnes 2F-ETI
    2,349
    44
    Jan 11, 2006
    Melbourne
    Are you using a genuine head gasket or after market?
  13. bsevans
    bsevans Focus on the Journey
    2,009
    Media:
    50
    13
    Jun 9, 2005
    Southern Arizona
    First, did you buy a tap to chase the threads in the block? If not, you will not know what the torque on the head really is. You will be amazed at what comes out of the bolt holes in the block You can test the bolt holes in the block by threading a head bolt into each bolt hole by hand. If you cannot easily screw it in by hand then the added torque required to just thread the bolt in is torque that would need to be compensated for when installing the head. You can buy the tap at mscdirect.com. Personally, I would never use thread locker on the head bolts. You're better off using a light lubricant. I've never seen in any FSM a call out for thread locker on head bolts. I might add, I've never seen a head bolt come loose. The older head gaskets (dimpled metal) require that the head be re-torqued after the engine has been run for a limited time. The newer head gaskets supposedly do not require the head to be re-torqued.
  14. Degnol
    Degnol
    8,123
    Media:
    16
    6
    Jan 22, 2003
    Kansastitty
    This ought to be good....we can get a 5-year followup on his success/failure:D
  15. donny paradise
    donny paradise
    613
    Jan 3, 2006
    Paradise
    Who are you 2 cats replying to? The thread was brought back from '03. techninja ask about re-torque hot or cold... 2/27'09 :doh:
  16. Pin_Head
    Pin_Head
    13,752
    1,321
    Feb 6, 2002
    OC, CA
    X2
    If it has failed repeatedly one of them isn't flat.
