So long story short, after swapping in a new 22RE, she won't start. It cranks really slow for half a second or so, then dies. Almost like the starter isn't getting enough power. And it's throwing code 51. It's got a brand new battery but I'm thinking some of my grounds are not where they're supposed to be. I'm about to redo them all, and ground the starter directly to the - post on the battery. Before I do that I want to make sure my timing is where it's supposed to be before I crank it again.
I'm getting different answers when I search. Some people say the Carbed 22R's are supposed to be at 0 degrees when you stab the dizzy and the EFI 22RE's are supposed to be at 5 degrees before TDC. Can anybody clear this up? I'm gonna try to attach some photos with my cranshaft at 5 deg BTDC, Cam gear at 11:00 or so (it's at like 11:59 at 0 degrees but the pic shows it with the crank being 5 BTDC), and the last pic is my distributor as it sits now, pointed towards the #1 cylinder (after being inserted with the crank at 5 BTDC.
Let me know if this looks right. I still got some time as I'm gonna work on the grounds before I try to start her again. But basically, do I want to stab the distributor at 5 degrees before TDC OR exactly at 0 degrees top dead center on a fuel injected 22RE??
Thanks in advance
Thanks in advance
