I know this is an old post, but if it's still leaking you might want to try this. I was complaining to LoCrwln (Here) about the OEM bulb seals on my '01. He put surgical tubing inside the closed portion of his door seals (2001) to help his seals. he gave me some left over surgical tubing and it's worked for me as well.
If you open the door and look at your door sill, you should be able to see the joint/seam for the doors' bulb seal. Pull one end away and you'll see the closed loop portion that makes the "Bulb." that's where we inserterted the surgical tubing.
