2 lo
Discussion in '40- & 55-Series Tech' started by customcruiser, Jun 10, 2003.
  1. customcruiser
    customcruiser Old Member
    278
    Jun 10, 2003
    Mooresville, NC -- Lake Norman
    I have a 71 FJ40 with the vaccum knob 4wd. I have read that you can't go into 2low only 2hi, 4hi, 4low, and neutral.
    I can ride in 2low it even takes off better than in 2hi or 4hi.
    Will this hurt anything? No crazy noises from anywhere. I have been shifting like this for about 4 months now. I leave it in low and switch from 2 to 4 only.
    This 40 is not street legal so I am not worried about speed.
    thanks for any help.
  2. fj40crusher
    fj40crusher
    463
    4
    Nov 7, 2002
    Pacific NorthWest
    So basically your leaving your transfer engaged in low and driving around in 2 wheel drive?
  3. woody
    woody Internet Fireman Staff Member
    10,333
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    I run offroad in 2lo all the time...you (obviously) cannot shift from 2lo to 2hi, but swapping from 2lo to 4lo offroad is very common.
  4. bad_religion_au
    bad_religion_au
    2,212
    Apr 24, 2003
    i got a stock 76 transfer case, does it do damage to go into what is labeled 4lo with the free wheeling hubs unlocked? this is the method for doin ramps and the like, but i read somewhere ??? that it's a bad thing to do, strips something upfront...
  5. woody
    10,333
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    You can switch into 4lo with the front hubs unlocked ONLY if you are also 100% NOT moving....you will have gear issues if the truck is rolling at all, since none of the front drivetrain is moving and it will have to force into gear.
    2lo is an EASY modificiation on a FJ40. Pull the shift boot. Look down the opening. You'll see a steel plate with a "L"-shaped slot for the transfer case shift lever. Take a small saw, torch (IMO works best), or get creative and turn this "L" shape into a square. Takes seconds.
  6. rocrawler
    rocrawler
    69
    Sep 11, 2002
    I put a twin stick on my 72' FJ40. That way running 2lo is the same as running 2hi and I can shift between the 2 while on the move.
  7. bad_religion_au
    bad_religion_au
    2,212
    Apr 24, 2003
    ok, but once shifted, is it alright to drive on it??? or will it chew out the front free wheelers, even if selected while stationary
  8. woody
    10,333
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    drive plates or lockouts?
    If lockouts, no problem....I would not do LONG drives, but short/occasional ones aren't gonna hurt a thing.
  9. bad_religion_au
    bad_religion_au
    2,212
    Apr 24, 2003
    yeah, i was only going to use it to ramp it up during the rear spring conversion to see the RTI difference of each stage, but was told NEVER to do it. ahh well i trust you guys more.
    stages will be
    stock.
    stock springs with clips open
    stock with clips open, no shock to see if shock limiting factor
    60 series springs
    60 springs with clips open
    60 springs with no shock and clips open
