quick smoke quesiton on my troopies (1997 HZJ75) ageing 1HZ
on a run donw a big hill - running against compression all the way donw at about 60kmh for about 4 minutes, get to the bottom and put the foot down - fair bit of white smoke out the exhaust for a good 15-20 seconds, also after being sat at the traffic lights for a while and then on take off a small puff of smoke (grey/white)
Wife was driving behind me up the hill the other day and said was blowing a bit of white/grey smoke (under load)
Assume that my valve seals are worn, we use a bit of oil but not much - could the smoke under load be underfueling?
She has done 360,000km and starts fine cold but after a long run turns over a lot before firing - assume this is because the oil is "thinner" when hot which means compressions must be down too?
