1991 FJ80 won't start/crank
Discussion in '80-Series Tech' started by rustycruiser, Aug 30, 2003.
  1. rustycruiser
    rustycruiser
    158
    21
    Feb 25, 2002
    Maryland
    Recently, my 91 80 series doesn't want to start. Turning the key results in a click (kind of like a solenoid opening/closing noise) but nothing else. No cranking, no starting. I don't believe that this is the infamous EFI relay. I took care of that problem a few years back. (Plus, the symtom of a bummed EFI relay is it will crank, but not start.)
    Anyone have any ideas. This happens on occasion. Other times it fires right up.
  2. Photoman
    Photoman SILVER Star
    1,145
    Media:
    41
    47
    Mar 28, 2003
    rusty-
    Starter solenoid contacts.
    Bill
  3. Photoman
    1,145
    Media:
    41
    47
    Mar 28, 2003
  4. ParadiseCruiser
    ParadiseCruiser
    620
    Mar 27, 2003
    Yep, I concur with Bill. Sounds like the starter solenoid contacts are burned, especially if the problem has been slow in coming on... and has gradually worsened. This is a fairly inexpensive fix as well, if you are handy enough to be able to R/R the starter on your own.
    Try jumping from another battery to rule out possible battery problems.
    Cheers, R -
  5. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,605
    2,983
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Do not ignore failing contacts as though that's all you get. They can "weld" in an attempt to start and then ya can't shut 'er down :eek: So, be prepared to pop the hood and jerk the negative battery cable to save the rest of the electrical system ;) .
  6. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,778
    308
    Dec 13, 2002
    Knee deep in hookers and gin
    [quote author=cruiserdan link=board=2;threadid=4826;start=msg36655#msg36655 date=1062346557]
    [/quote]
    Tapping on the starter with a hammer can free up the welded contacts in many cases after you pull the neg cable. It's a temporary thing though. they'll weld up again.
  7. rustycruiser
    rustycruiser
    158
    21
    Feb 25, 2002
    Maryland
    Thanks for the advice, gentlemen.
    I will replace the contacts ASAP.
    :D
  8. ovrroks
    ovrroks
    55
    Jan 14, 2003
    My '95 (125K miles) started the "click"=no start thing today.... It'll start after turning the key a few times, but the first couple trys I just get the "click"
    Ross, Did you replace the contacts and did that take care of the problem? I want to take care of this before it goes any further...
  9. cruiserdan
    20,605
    2,983
    Mar 27, 2003
    Ovrroks,
    It sounds like it's time for contacts for you. I suggest you replace them at your earilest convience. Parts will run you under 25 bucks.
    D-
  10. ovrroks
    ovrroks
    55
    Jan 14, 2003
    [quote author=cruiserdan link=board=2;threadid=4826;start=msg38407#msg38407 date=1062816140]
    Ovrroks,
    D-
    [/quote]
    Thanks CD, You wouldn't happen to have those part numbers handy would you? :D
  11. Brentbba
    Brentbba Former Golfer SILVER Star
    9,824
    321
    Mar 27, 2003
    OC, CA
    Ross and Ovrroks,
    Head Dan's advice! I waited too long with the starter clicking. I knew that was the problem from having one starter go earlier in my '94's life. What happened is exactly what Dan describes, I fried my alternator and drained my battery. I don't wrench so replacing both starter and alternator was in excess of $1K for remfg's. Battery took a charge so didn't replace it. TAKE CARE OF IT NOW!
  12. cruiserdan
    20,605
    2,983
    Mar 27, 2003
    Contacts for the 2.0kw srtarter are 28226-72010 and 28226-66060. They list for $11.72 each.
  13. rustycruiser
    rustycruiser
    158
    21
    Feb 25, 2002
    Maryland
    28226-72080 and 28226-72010 are the part numbers I got via http://www.elcats.ru/toyota/nahodka/fullimg.asp?piid=6106&smod=1&cid=472&treg=U The 66060 number is also still active, according to my parts manr. Replacing the contacts solved my problem. Took about an hour to do. Getting the top starter bolt out was the only PITA of the whole procedure. Working by feel in the space that a two year old's hand doesn't fit sucks! :D
    Ross
  14. cruiserdan
    20,605
    2,983
    Mar 27, 2003
    The 28226-72010 applies to the 1.0kw 3FE starter (which is correct for Ross). The 28226-72010 is used on the 1.0kw 3FE and the 2.0kw 1FZ.
    The 2.2kw (93 only) 1FZ uses 28226-54100 and 28226-76100.
    The 1.4 kw 1FZ starter uses 28226-64370 and 28226-74070
