Cam cog mark has rotated in the down position I don't remember which way it rotated when disassembling....which way should I rotate it to align to the marks clockwise or counter clockwise or does it matter. Will the valves make contact with the pistons on either rotation , and is one rotation a full cycling of the valves on one side of the engine.
What is the torque specs for the cam cog bolt.
When I pulled the crank pulley bolt I am not positive if I over rotated since I used the starter to crack the bolt...if I pull the distributor cap and the rotor is in the #1 position this should be TDC..... correct as long as the cranks marks are aligned. Is the engine supposed to be TDC when all cam and crank marks are aligned.
What is the torque spec for the crank bolt.
The Tbelt is marked left cam and right cam which is which .....PSide left or right DSide left or right.
