- Location
- United States
Hey Y'all,
F.S. 1981 Landcruiser BJ-42 (Diesel) Located in Summerland, B.C.
Please take the time to read this ad before asking questions regarding my Cruiser… Thx.
3B diesel engine, 4 speed trans, lifted on 35" Dick Cepeck Mud Country tires (80%+ tread) with stock springs.
It’s painted the stock colour of Lt. Beige with a matte finish. It runs perfectly, no smoke and has a ton of torque. The disk brakes all around make it stop amazing and it doesn’t pull one way or the other.
The following has been replaced or refurbished within the last 3 years:
Frame, Axles, Undercarriage:
- Replaced the frame, which was sandblasted, metal prepped and coated with POR 15
- Front axle replaced with a cut and turned unit from EBI including larger spring perches. Axle was rebuilt entirely with all new bearings, marlin crawler inner seals, etc
- Rear axle sandblasted and rebuilt. Third member replaced with a unit from the front axle of a BJ42 with only 50,000km on it.
- Locking hubs rebuilt
- OEM axle breathers and extended lines
- 4 wheel disc brakes all around with working e-brake including new master cylinder, brake lines and brake booster from a 60 series Landcruiser
- Factory Toyota BJ42 exhaust installed
- Heavy Duty 4Plus anti-inversion shackles and greasable pins with rubber bushings.
- New fuel tank
- BDS shocks and custom shock hangers
Steering
- Manual steering box from a low mileage unit
- Tie rod ends
- Old Man Emu steering damper to fit OEM location
Drivetrain
- 3B 4 cyl diesel engine rear main seal, oil pan and push rod cover resealed
- Water pump
- Glow plugs
- Ring gear
- 4 speed transmission and transfer case output seals
- Clutch, bearing and clutch slave cylinder
- Speedo cable (including correct markings on the speedometer to reflect the change in speed with the 35" tires
- valve clearance adjustment done
- Racor fuel/water separator installed
Interior
- Heater rebuilt with all new hoses and fittings
- Rear bench seat from a newer jeep including the correct brackets to bolt it to the floor from Teraflex. 3 point seat belts built into the roll cage with proper child seat hooks
Miscellaneous
- Round eye headlights (very bright)
- Brand new windshield
- Have a BFG Mud spare tire mounted on same rim (& spare tire carrier for back)
My intention was to replace the tub and front fenders with aluminum ones, but never got around to it. It’s had steel body panels welded in where old rust used to be. It shows well, but tub still has a few areas that I’d suggest attending to in the future. It’ll need new window/door seals, roof seal, drivers side door lock, headliner and other things if you want it to be a collectors vehicle. The factory hard top is painted the same colour with all glass in good condition. Comes with a bimini soft-top as well. I have two seats from a WRX that will go with the truck (the current ones have been installed temporarily). Our second child is nearly due and we are actively looking for a Diesel 60 series Landcruiser Wagon instead. That’s the only partial trade we’d be interested in. Sad to see it go, but won't be my last Cruiser.
Thanks for reading. $18,000 (CDN) obo
- New fuel tank
Steering
- Tie rod ends
Drivetrain
- Water pump
- Glow plugs
- Ring gear
Interior
Miscellaneous
