- Thread starter
- #21
Yesterday I ran into an issue. After grinding the back rib of the shock tower flush, the box would not sit flush with the frame. There was a gap where the bottom bolt hole meets the frame. I ended up removing the shock tower then grinding the underside of the of it and putting some washers under the top side. I tested and now it sots flush. hopefully I will have time to run to the hardware store today to get some grade 8 cad plated bolts. Then I can bolt the shock tower back on. And this Saturday hopefully weld the plate on the backside drill the holes, weld the tubes and bolt on the box. Picture shows the little bit it was out. Will have more pictures this week..
