- Thread starter
- #21
Cool. Is your truck spring under? or spring over?
What tires do you have?
Typically in Chevota conversions the radiator is too far forward (too far in front of fan blade), so the radiator normally gets moved back a couple inches. That means that you could actually motor mount the 350 more forward than my installation instruction manual calls for, thus giving you some more rear drive shaft. Send snail mail address and I'll send you a freebie manual Flipper. Also, if you find that you don't have front Chevota mounts lemme know, I have a couple sets left at somewhat econo price.
Sprung over,35's, sbc, nv4500, orion tc.Cool. Is your truck spring under? or spring over?
The previous owner butchered one quarter and had the second one started. He also started air chiseling the mount for the dash pad on the drivers side. ...i'm not sure if I will try to fix that, or go ahead and shave it from the dash and go street rod on the dash. Hopefully the quarters will be easy to fix.
We started mocking things up to see what we are missing.
Right now it looks like I am missing a bunch of bolts...and a steering column. I need to search the barn for more FJ40 stuff.
Tomorrow it gets rolled outside to be washed off.
Right now, I don't like the looks of the lift springs and longer shackles. I want to go springover on the 60 springs and 60 axles (getting rid of the 5 lug Suzuki samurai wheels will make it look better too.)
