16 inch, split rims or one piece?
Discussion in 'Diesel Tech / 24 volts' started by Doug384, Jul 26, 2010.
  1. Doug384
    Doug384
    224
    Jun 4, 2008
    Picton, Ontario, Canada
    I have found a source of both types of rims. Anyone have any opinions that they care to share as to which they prefer or would choose? Yes, I am getting new tires.
  2. cruiser_guy
    cruiser_guy
    11,209
    22
    Jan 20, 2003
    Wherever the truck stops!!
    Non-split. You will likely have problems getting tires mounted on the splits. I have NEVER encountered a place that cannot deal with standard rims even in darkest Africa and in Central America.
  3. Doug384
    Doug384
    224
    Jun 4, 2008
    Thanks for that tip.
    What is the issue with the split? I thought that the tire could be pushed on with a standard iron? Doesn't that make trailside repairs easier? Granted some tire changers don't want to inflate them but then most truck tire dealers have cages for the split rims don't they?
  4. cruiser_guy
    cruiser_guy
    11,209
    22
    Jan 20, 2003
    All true! Remember though that some tire shops won't do them and those that do WILL charge extra each time to mount tires so which do you want?
    I've spent time in Central America and I'm about to go to Africa with my 'Cruiser and I'm NOT interested in splits.
  5. blis
    blis
    733
    4
    Jun 4, 2009
    in cold north
    split rims are also a potential deathtrap in case of inexperienced ppl working with them... so, i'd non-split all the way...
  6. Radd Cruisers
    Radd Cruisers
    7,927
    60
    Sep 28, 2002
    Vancouver Island BC Canada
    Get one piece rims. Tires for split rims (tube type) are getting harder to find.
    ~John
  7. lostmarbles
    lostmarbles SILVER Star
    8,782
    Media:
    100
    1,208
    Sep 3, 2007
    New Zealand
    I'm a geriatric weakling and I still manage to change my own tyres in my driveway. (And so far I've never killed myself once.)
    The danger-scare of splits is born out of ignorance.
    But if all your local tyre people are ignorant ... and you're not inclined to change tyres yourself .... don't choose splits.
    :cheers:
    There's no special requirement for tyres associated with splits! :frown:
  8. Neddy
    Neddy
    40
    May 28, 2009
    Los Angeles
    I think it's personal preference.
    I tend to like my junk to be just a little different than everyone else's, so maybe that's why I like splits.
    I have them on my 80.
    Just got new tires over the weekend. There are a few inconvienences related to them:
    It is true that not all shops will work on them. First two places I went said no, third said no problem.
    Those places that will install them are not likely to have them on hand. I ordered mine in the afternoon and they got them in the next morning. I doubt that you will be able to drive in and leave with new tires like you typically can with tubeless tires.
    There was a $25/tire surcharge to mount them. And it took almost 2 hours to complete.
    After all that though, they ride like butta smeared on velvet, so I couldn't be happier.
  9. bigbrowndog
    bigbrowndog
    1,662
    9
    Apr 30, 2005
    N.Q. australia
    Have you ever repaired a puncture in the bush?
    Please tell me the problems you encountered doing a repair on a split rim.
    Some pluses are.
    No need to break the bead.
    You only need two decent screw drivers to remove the split rim.
    A hand pump/foot pump , small compressor is all that is needed to inflate the tire and seat the rim. If you inflate steadily and check the split rim there is very little chance of the rim coming adrift.
    Very easy, low energy repair in isolated places.
    Limits carrying extra wheels in isolated places.
    My Dislikes.
    With a puncture it instantly goes flat.
  10. Doug384
    Doug384
    224
    Jun 4, 2008
    "With a puncture it instantly goes flat."
    That is a really good point that I had almost forgotten. I remember having an instant flat on a loaded motorcycle at speed years ago. Luck had it that I did not end up in the oncoming traffic in a head on. Most of the tubeless tires of today seem to let go way slower.
  11. cruiser_guy
    cruiser_guy
    11,209
    22
    Jan 20, 2003
    I've never run splits and in Central America there was a "pinchazo" or "llantera" all over the place ready to fix flats. If I had the unfortunate luck to blow both the main tire and the spare I carry plugs. I have not needed them but I have seen folks use them. In Africa the tire "shops" are less frequent but still around.
    Instant flat at speed would make it a deal breaker for me. Keeping a loaded 'Cruiser between the ditches, and out of on-coming traffic, when a tire goes flat instantly would make for an interesting time!!
  12. herbs
    herbs
    468
    2
    Dec 27, 2006
    Queensland, Australia
    But then again I've yet to see an instant catastrophic sidewall failure with split rims, seen it plenty of times with tubeless tyres, especially Coopers. As long as the inside of the rim is kept pretty clean the split rims go real well. Older rims that have been neglected get rust on the inside, it dislodges and that's the cause of a lot of punctures.
  13. goldchaser
    goldchaser
    838
    27
    Oct 19, 2005
    Kalgoorlie,Western Aust.
    Go tubeless Buy yourself some decent tyre levers doug,plugs and some patches,you can usually plug most punctures on the car.
    A small tool for scuffing inside of tyre if you have to patch it.
    A beead breaker if you feel you need it.
    Hand levering a tubeless tyre off a rim is not such a big job,it is actually easier then say motocross bike tyres if youve ever done them.
  14. RufusTheDufus
    RufusTheDufus SILVER Star
    2,506
    Media:
    14
    59
    Jan 9, 2008
    Maine
    I've done quite a few motocross tires over the years. That's why I've never attempted to do a tubeless car tire. I always thought they would be more difficult. The paddle tire I rad on my KX500 for the sand dunes was the hardest tire I've ever had to change.
  15. lostmarbles
    8,782
    Media:
    100
    1,208
    Sep 3, 2007
    New Zealand
    I can see no reason why tubed tyres would be any more susceptible to "getting an instant flat" than tubeless.
    And splitrims themselves don't encourage "instant flats" IMO.
    In fact I've never ever had an "instant flat" occur on my BJ40. And yet I've always run splitrims (and consequently always run tubed tyres). But I have had about three or four "gradual flats" in that period.
    Any explanation of your reasoning/experience here Gazza?
    :beer:
    PS. With a motorcycle, you only have one wheel/tyre on the front so getting an "instant flat" there is ALWAYS going to be very scary (and can easily be lethal). So anyone that has experienced one will never forget it. ............... But such memoroes are no reason to blame tubed-tyres per se.
  16. goldchaser
    goldchaser
    838
    27
    Oct 19, 2005
    I bet a paddle tyre is hard
    Much more sidewall on the 4x4 tyres hence more flex rufus.
  17. bigbrowndog
    bigbrowndog
    1,662
    9
    Apr 30, 2005
    N.Q. australia
  18. bigbrowndog
    bigbrowndog
    1,662
    9
    Apr 30, 2005
    N.Q. australia
    Cheers, I find them a lot harder to get back on the rim [talking toyota]. Also if you have to drive a short distance to be able to jack up the truck safely it can be really hard to get the tire to initially seal so it will pump up. You can actually repair a split while it is on the truck, bit hard with a tubeless.
  19. goldchaser
    goldchaser
    838
    27
    Oct 19, 2005
    Youve never seen a tyre plugged while its still on the car?
  20. bigbrowndog
    bigbrowndog
    1,662
    9
    Apr 30, 2005
    N.Q. australia
    Some pluses are.
    My Dislikes.
    With a puncture it instantly goes flatLOL,
    Goldchaser wrote/
    Think you need to reread the post.
    Mate I am not talking about picking up a screw or nail in town. However I have never seen anyone remove a tubeless tire while the rim is on the car.
