100 Series Brake Pads
Discussion in '80-Series Tech' started by Eduardo96FZJ80, Jun 12, 2003.
  1. Eduardo96FZJ80
    Eduardo96FZJ80
    634
    Apr 1, 2003
    C-Dan,
    I stopped by the local dealer yesterday, while looking @ the front pads for the 100 series. I saw to different sets. The only difference apears to be the type of material.
    Which type are you running in your rig? (I'm checking for previous posts)
    Also, when I R/R the belts I damaged the 14mm locking nut on the AC tensioner pulley (twelve pt sockets suck) do you by chance have a part # other than the pulley assembly?
    Thanks
    Eduardo
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,603
    2,981
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    I'm running 04465-60151. There is also an 04465-60190. the latter is used for '02 up. The 60151 is made by NBK, the 60190 by Sumitomo. The cailpers and shims are also different. I do not know what the difference(s) is/are. I am pleased with the 04465-60151's on my vehicle. If you go to 100 pads you will need new rotors or have the existing ones re-surfaced.
    Ya gotta buy the pulley to get the nut (88440-26090 $27.23)
  3. Eduardo96FZJ80
    Eduardo96FZJ80
    634
    Apr 1, 2003
    C-Dan,
    The 04465-60151, was my choice of the two. It seemed to be the less aggresive of the two.
    Is the resurface of the rotors a must? Will I be more likely to warp them? I am currently running the cross drilled rotors with Autozone high performance pads.
    No real bad complaints with this setup, other than the usual, annoying squeal and not as smoth stops after the pads are @ about half worn?
    I'm sure my driving habits are a bit to blame :G
    Eduardo
  4. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    Eduardo.
    A fresh rotor surface is a must as the 100 pads have a larger surface area. In other words, they will have a different "contact patch" on the rotor, overlapping wear/no wear areas.
  5. Eduardo96FZJ80
    Eduardo96FZJ80
    634
    Apr 1, 2003
    I see, says the blind man!! Now I see why ! :stupid:
    humm?? maybe I'll just run the same pads I'm running for now,and save the 100 series pads for when I have the time to R/R the rotors and resurface them.
    Thanks again.
    Eduardo :beer:
  6. tenncrusher
    tenncrusher
    168
    Mar 28, 2003
    Nashville, Tennessee
    Dan, I still have some pulsing in my peddle after changing front pads and rotors. I do not think I have done anything to warp them. They seem to have gotten worse since putting them on.
    I think some is coming from rear as when I pull my park brake at 10-15 mph, it pulses a little.
    Should I have the rear rotors turned? The pads are good, per my mechanic.
  7. Eduardo96FZJ80
    Eduardo96FZJ80
    634
    Apr 1, 2003
    Teencrusher,
    For some reason, I seem to notice "the pulsating" brake action when the pads,( front or rear) are @ 50% or less ??
  8. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    Tenn,
    If you feel a pulse in the ebrake lever at least some if not all of what you are feeling is coming from the rear. A good machinist can turn them. They are a bit odd to fit on the arbor so it is nice to find somebody who knows whats up.
    I don't know what to make of "used" pads on a new rotor surface. Any body else??? You may want to consider new rotors and pads and then forget about it for a while to come.
  9. tenncrusher
    tenncrusher
    168
    Mar 28, 2003
    I have the pads that you sent with the others. I will probably have the rotors turned and have the pads put on. My mech checked them when he put on the front and he said they were good.....nice to have an honest guy working on your truck.
  10. Eduardo96FZJ80
    Eduardo96FZJ80
    634
    Apr 1, 2003
    C-Dan,
    When I installed the cross drilled rotors, I tried the "used pads" (no pun intended) &nbsp:Didn't work well @ all, had to go get a new set.
  11. Photoman
    Photoman SILVER Star
    1,145
    Media:
    41
    47
    Mar 28, 2003
    Used pads on a new or turned rotor are not a good idea. Many times the rotor has grooves in it that are duplicated in the pads. By putting the used pads on for a while you are just hitting on the "bumps" which not only can affect braking but start to put grooves in the new rotor. If the pads are in good shape, (thick) what I have done is put a piece on sandpaper on a block of steel or wood and rubs the shoes down flat. The operative word here is flat. Don't sand a taper on the shoes.
    Bill
  12. Eduardo96FZJ80
    Eduardo96FZJ80
    634
    Apr 1, 2003
    Just wundering?? How the e-brake, would be a factor in the vibrations? are they not two different braking systems?
    one the rotor/pads and the other a drum with brake shoes? :givemebeer: :givemebeer: It's Friday!!
  13. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    Valid point.
    the rear rotors do two things. they are in essence a rotor and a drum. So, the service brakes are "disc" and the parking brake is drum. That being said, if the parking brake application produces a pulsation in the lever, it could also affect the "disc" portion of the rotor.
  14. Eduardo96FZJ80
    Eduardo96FZJ80
    634
    Apr 1, 2003
    C-Dan,
    Point taken !
    You have yourself a good one!
    Salud :beer: :beer:
