1 ton chevy axles under fj60
Discussion in '60-Series Wagons' started by akfj60, Jun 22, 2003.
  1. akfj60
    akfj60
    4
    Jun 22, 2003
    when i do my v8 swap i am thinking of putting 1 ton axles under my 60.has anybody seen on done like this?i will be running 44's in the future so i want the extra width and strength.also my stock t-case is stuck in low range.it will go into 2wd and the shaft going into the t-case moves with the linkage.what might of broken?
    thanks mike
  2. Man Jerk
    Man Jerk
    2,107
    3
    Jun 28, 2002
    Colorado Springs, CO
  3. Chef
    Chef
    1,972
    6
    Jan 24, 2003
    Columbia, MO
    Not much to be wrong internally in the tcase-shift fork could be bent, but I've never seen it, they're pretty stout. It's more likely to have a stuck, never been lubed, bunged linkage...
  4. akfj60
    akfj60
    4
    Jun 22, 2003
    thanks for the pic yeti :G now i have to find a set of axles.what did he do for steering?was thinking about using a chevy steering box and linkage adapted to the toy colume. chef-the shaft that goes into the t-case moves and the linkage is all in working order.it isnt a big deal as i tow it every where i take it.but hi range would be nice for going trail to trail. thanks guys
  5. Man Jerk
    Man Jerk
    2,107
    3
    Jun 28, 2002
    I couldn't really tell you anything about the truck. I've never actually seen it.
    If you pop on over to the forum on the MN toyx4 site, he frequents there under MRTLC4x4.
    http://www.mntoyx4.com/forums/
  6. kling-on
    kling-on Kool Arrow
    5,422
    Media:
    12
    68
    Apr 26, 2003
    Pimpin part in SanAntonio TX
  7. Medusa
    Medusa
    416
    1
    Jun 17, 2002
    Do you really think the LC transfer case will hold up to 44" tires and one-ton axles? I don't.
  8. akfj60
    akfj60
    4
    Jun 22, 2003
    when i do the swap it will have a 350,th400 and 205 tcase in it all toy running gear will be gone.we will be moving to florida and 35s wont work in the muck down there.
  9. kling-on
    kling-on Kool Arrow
    5,422
    Media:
    12
    68
    Apr 26, 2003
  10. alaska60
    alaska60
    2,909
    13
    Apr 27, 2008
    Taos, New Mexico
    This blue 60 is sitting on 1 tons with H1 military 8 bolt 37 beadlockers........ its an animal!
  11. brian
    brian SILVER Star
    7,346
    770
    Feb 7, 2003
    lebanon,pa
    is that the continental divide in the back ground?
  12. alaska60
    alaska60
    2,909
    13
    Apr 27, 2008
    Taos, New Mexico
    No.... just another hill out here.
    aint no poconos!
  13. StevoJonesFJ60
    StevoJonesFJ60
    1,992
    3
    Nov 22, 2010
    Central NJ
    I am in the process of swapping one ton running gear into my cruiser and plan on reusing the stock FJ60 steering box. As for swapping axles its not too bad if you are using a leaf spring suspension.
    If you are planning on running 44" tires you might want to swap a 14 Bolt out back and upgrade the 60 to 35 spline inners and outers. especially if you swap a healthy V8 in there.
  14. Elbert
    Elbert SILVER Star
    8,230
    269
    Jul 20, 2006
    AL, USA
    look over in the hardcore section...there is a thread or two on 14bolt swaps.
