01 3rd gen 4Runner Power antenna replacement
Discussion in '05+ Tacoma, T100, Highlander' started by 2ndGenToyotaFan, Nov 17, 2007.
  1. 2ndGenToyotaFan
    2ndGenToyotaFan Ice-Bound Moderator
    9,183
    39
    Jan 8, 2006
    It's complicated....
    Well, it broke... just like the one in the 90 4Runner we used to have. The plastic geared push rod snaps near the end and the antenna goes up, but not all the way and the motor just runs untill you pull it up.
    I asked here about changing to a regular whip antenna, and was given this link:
    http://www.4runners.org/writeups/whip/index.html
    That looked like a lot of work... So I got a new OEM one off ebay for $25 shipped.
    First step, is to remove the tire, so you have room to remove the front trim of the running board. There's 2 nuts from the bottom, and 2 screws from in the wheel well.
  2. 2ndGenToyotaFan
    9,183
    39
    Jan 8, 2006
    Next step: Remove the antenna. I used a flat blade screwdriver to unscrew the top crome trim ring (Always pull towards yourself so you don't slip and scratch the paint) and there's one 10 mm bolt holding the bottom end in place.
  3. 2ndGenToyotaFan
    9,183
    39
    Jan 8, 2006
    You need to remove the antenna assembly, because if it broke.... then it left parts inside, see broken rod in the plastic ring thing.
    If you wanted to just replace it as PM, you could do the whole job just by removing the chrome ring on top, and pulling it out. And it would take 2 minutes instead of 30...
  4. 2ndGenToyotaFan
    9,183
    39
    Jan 8, 2006
    Once the chrome ring is off, you can remove the old "mast" by turning on the stereo and selecting a setting that will extend the antenna, as it does this, just pull it out.
    Once you have the broken peice out of the assembly, installing the new mast is just a matter of turning off the stereo so the motor will start to retract the mast, and as it does this you push the end of the new push rod down the hole...
    Make sure the teeth are pointed in the right direction. If the motor is back in the vehicle, then you want the teeth to point forward. If the motor is not installed yet, you want the teeth to point towards the motor on the assembly.
    Then put the chrome ring back on, and tighten. Then install the 10mm bolt, and put the rest back together.
    Clear as Mud right? :D
  5. Jetboy
    Jetboy
    1,213
    33
    Sep 16, 2004
    sweet. I need to do this soon. Thanks for the play by play!
  6. 2ndGenToyotaFan
    9,183
    39
    Jan 8, 2006
    No problem, I figured it would help someone... :D
  7. Mars
    Mars
    452
    44
    Feb 24, 2005
    Namby Pamby Land
    Beautiful writeup. Thanks for investing the time! Good example of what the FAQ could/should be.
  8. 2ndGenToyotaFan
    9,183
    39
    Jan 8, 2006
    Thanks Mars! :cheers:
    FYI, my wife's antenna broke right around 80k miles.... So if anyone is thinking of changing it the easy way (Before it breaks) there's one benchmark.....
  9. hoch
    hoch
    641
    Aug 11, 2006
    Buried in snow
    I'm at 89k and mine is out. It goes up, but does not go down on its own. If I push it down slightly, it starts to go down. So I believe the first few teeth in the gears have broken off.
    However, I am going to take the "hard road" and install a Tacoma Whip. I do not feel like changing out the antenna ever again and the constant up and down thing was starting to get annoying anyway.
    I need to get on this before it gets too cold. :D
  10. 2ndGenToyotaFan
    9,183
    39
    Jan 8, 2006
    Hey, you should do a write up.... :D I feel your pain, when the wifes old 90 broke it's antenna I changed to a whip, but I had a good pick N pull nearby then....
  11. 97kurt
    97kurt
    131
    Jul 23, 2007
    Reno, NV
    I just disconnected mine when it started to make noise. The antenna in the rear window works good enough by itself that I don't miss the one in the front.
  12. Ron Helmuth
    Ron Helmuth
    69
    Feb 23, 2007
    Denver metro area-COLO.
    thanks for the write up and the pictures- that is most helpful for those of us non- mechanically inclined
  13. 2ndGenToyotaFan
    9,183
    39
    Jan 8, 2006
    Aftermarket? Or is that the thing on the rear pass side window? I thought it was another defroster thing... that would have been good too....
    I like pics too, especially close-up good ones! :D
  14. neliconcept
    neliconcept
    14
    Jan 2, 2007
    very nice, gonna end up removing mine as it rubs the dryer hose im using for my snorkel
  15. raydouble
    raydouble
    1,523
    Media:
    13
    1
    Feb 11, 2008
    Rochester, WA
    Awesome writeup Jerod. :)
    Just found this.....going to add it to the FAQ
    :cheers:
