If you take a look at your air flow meter, you'll probably find an old and worn out orange dot that was put on for some unknown reason as the car was being made.
I think most people tend to neglect maintenance of this dot, so it's likely yours needs to be replaced. Here's how you do it:
First, you need to know someone who scrap books. Point out the sad looking orange dot and then ask them if they could make you a new orange dot. They can all do it, so don't let yourself be tricked. The tools they use to make custom orange stickers are in the picture below.
Next, get the old sticker a little bit wet, and rub it with your fingernail until it comes off. This is going to take you somewhere around a minute. Be sure to dry the area before you try to use the sticker. Wet stickers don't work!
You then take the new sticker, and press it into place on the clean dry air flow meter.
That's it. I'm not sure why, but I started getting 2 MPG better right after I did this, and my approach angle has improved. Here's the end result, just like the day it rolled off the line:
