- Thread starter
- #381
Tacking then all burned in.. The steel I used is 16 gauge which is pretty heavy duty (and will have to be because the weight of the rear seat will be resting on it) but the 55 steel was thin, so it was hard to get good looking welds and I had a lot of problems with the welder burning in too hot.. In 110 mode I am having problems with the welder having enough juice (I think I need to go out and get a better extension cord) and on 220 (which is what I ran it on tonight) it is too hot even on the lowest setting.. Sort of like using a a 175 or a 210 machine for body work or something like that.. I had to tap-tap-tap and because my pieces were not perfect (ie there were gaps, even some big ones) I basically spent a lot of time tap-tap-taping away with the welder... I learned the technique from proffitts one time, they use pretty much big machines for everything at least last time I was down there...
