cruiser_guy
Out of Africa / North Africa
Another lister poted the Federal Mogul number 724956085880 but it doesn't show up on their database and when I search for a seal to fit a 33mm shaft and a 40mm bore I get NOTHING! The inner axle seal surface diameter is 33mm and the bushing OD on the old axle is 40mm. Am I missing something? Is this a special seal of some kind?
I can find a Chicago Rawhide seal for a 32mm axle and 40mm bore but then I need to turn down my axle to suit and I'm not sure there is enough room for the splines of the axle to fit through the smaller seal without damage.
I know others must have done this conversion. What seal did you use? Or did you machine the old housing to take a larger seal?
This is the spec's on the Chicago Rawhide seal for 32mm shafts and 40mm bore:
Stock Number
12672
Description
LDS & SMALL BORE SEAL
Lip Code
Nitrile (Lip Code: R)
Type/Style
HMS4
Stock Number
12672
Description
Lip Code
Type/Style
HMS4
