Ok, I bought 6- 12 oz bottles of Toyota brake fluid and proceeded to flush the brake system, but ran into a few problems.
1. I was going to siphon/draw the fluid out of the reservoir with a syringe, but there are some bevels in there that prevent this. So, I thought I would just flush/bleed the lines.
2. Started with right rear, with assistant on brake pedal, cap on the reservoir, the ignition off. Got about 12 oz clear yellow fluid out- looked good. Checked the reservoir- still above the minimum line.
3. Went to left (driver's side) rear. Same thing, only about 4 oz's came out, fluid condition looked very good, then no more would flush. Repeated by closing valve, re-priming the brake pedal, opened valve. Again, only a small amount of fluid. At that point, I added 12 oz new fluid to reservoir.
4. Right front. pumped and held brake pedal, opened valve, a good squirt of brake fluid came out, clear as a whistle, then nothing. Closed the valve, repeated, and nothing. Turned key to acc (engine off) and tried it again, only getting a small amount of fluid out.
5. Same thing on driver's side front.
The good thing was the fluid appeared good as new. The bad thing was I thought I could run more fluid through it.
Anyone else tried this on a 100 series yet? Any tricks- I didn't know with the brake system the way Shotts described, if something else needed to be done. Also, what about a proportioning and bypass valve like on the 80's? The FSM mentions it, but doesn't say where it is or if it needs to be bled.
