All this talk of tires and my purchase today of a spanky new set of 305/70 Nitto's has me thinking about a speedo correction gear. When I had my 80 I bought a speedo gear from Slee..is there such a beast for the 100 to correct for 33's?
80and100cruisers said:I forget what the stock tire size was for my 99 cruiser. I just assume it was 30 inches, and that my 305s are 33 inches, meaning there was a 10% increase. So, I assume that the speedo is 10% off, meaning 30mph is really 33mph, 70mph is really 77mph, etc. My reasoning is that the 33 inch tire covers 10% more ground each rotation than the 30 inch stock tire. That seems like a huge difference, can anyone correct me if my logic is flawed.
Anyways, if Im' right the 10% rule is a cheap/easy method to judge your true speed.
-Matt
spressomon said:Actually if you compare the circumference of both sizes (275-75/16 & 305/70-16) you arrive at a net difference of 1.7%
275-75/16
D= (.75 x 275/25.4) x 2 + 16" = 32.24"
C= Py x D
C= 101.29"
305-70/16
D= (.70 x 305/25.4) x 2 + 16" = 32.81"
C=Py x D
C= 103.08"
The difference in percentage between the above two circumferences is only 1.7%. We all know the actual measurements of each brand of tire will probably be different than the theoretical diameter.
STATE TROOPERS! 6% of 80 MPH is almost 5 MPH. That's the difference between a speeding ticket and no ticket.e9999 said:who cares about 6%, sheesh....
hoser said:You sure it's not 275/70R16?
