I posted a few weeks ago about a vibration at 38 to 43 while accellerating only. I only feel it in the floor board and it seems to be ranging from 35 to 45 now also. The vibration started about 5,000 miles ago and I noted a light tarnishing on the outer wheel bearing on about 1/3 of the inner portion that contacts the spindle on either sideof the vehicle. I also did my 1st complete birfield repack 10,000 miles ago including ALL bearings and seals.
Now, so far I have done the following to narrow down the vibration: wheels balanced and rotated, greased all joints and shafts and this past week I installed a cdl switch from Slee. This is where it gets interesting. I first removed the rear driveshaft and inspected u-joints and drove it . Joints look fine and still have the vibration. Next the front drive shaft came off and voila the vibrationm is gone and upon inspecting I notice one u-joint is very stiff half way through its movement and the other is not as bad but still not as smooth as the rear shaft u-joints were. I also notice the -y- sections that holds the u-joint on the shaft are not in "time" , the front -y- is rotated to be exactly opposite the rear one. there is also a yellow mark on each piece of the shaft showing this is how someone wanted this lined up. So I have the toyota tech guys install new joints and they agree that the joints could be my source of vibration and that the driveshafts do not come from the factory lined up like this " out of time". I install the shaft with new joints "in time" and still have the vibration GRRRR. I then take it out and put it back in the way it was and still have the vibration DOUBLE GRRRRR. One quick observation I noted with the fron shaft out and center diff locked was that the clunk or thud I usually feel when coming to a stop was much more pronounced. Probably nothin but thought I should mention it.
Please Please guys help me out here. This one could seriously dip into my Slee fund!!
