I just got me a 76 FJ40 off of Ebay Sunday and drove it the 90 miles home while wobbling all over the road. It was an adventure.
It's got a Chevy 283 swapped in that seems to rock basically, and then an AA to mate it to the stock drivetrain. It definitely needs some work and I'm making a list.
While driving home I knew it had play in the steering and pulled left when braking. Come to find out the front right Rotor was COMPLETELY worn out to the point where I can push through it, the metal was so thin. And the caliper pistons and pads are completely shot.
One engine mount has a long bolt through it with no nut on the end.
Along with the play in the steering, the PO had said he'd replaced some of the tie rod ends and would look for the new parts that he hadn't yet installed.
I seem to gather that the front disc brakes are not factory? Is that correct? How do I then determine what replacement parts I need? Would it be possible to rebuild the caliper or would I be better off buying a replacement?
And what's the best way to determine the cause of the steering play?
If you can help me out with those two questions, I promise I won't ask any more for at least a month..err a week.....okay at least till tomorrow. Yeah, tomorrow.
I'll get some pics up when the wife gets home with the camera.
WELCOME !!!
New rotors are available from Toyota--contact CruiserDan. Get OEM and any other parts you might need and fix the brakes before you move it again....for your safety and the rest of the world.
