- Location
- United States
$12500 Firm
I have a Cruiser that has mostly sat in the garage for the last three years. It is 85% Restored. Just haven't used it much since I have bought my F150. Don't like to hunt out of it since I got it painted. Considering selling it. I have a 6" thick file of receipts, paperwork, manuals and catalogues. It was appraised for insurance four years ago at $16500. It is not an off frame restoration. The Cruiser originated in California and has been in the Southeast for the last twenty years. I have had it since 1995. It has a solid floorboard with no rust holes that you see in a lot of older vehicles. I am located in Grovetown, GA, 150 mi east of Atlanta. I put my Cruiser in late last year and decided not to sell. Re-considering selling.
Here are just some of the upgrades and replacements I have done.
4 Color Custom Clear Coat Camo Paint Job (HardTop and Doors Currently Removed)
It is painted Solid Green on the inside
Kayline “Fast- Trac” Tan Soft Top With Two Piece Removable Doors
Kayline Bikini Top
Re-upholsterd Front Seats
Rear Diamond Plate Insert for Soft Top
Extended Windshield Mount Mirrors
Purchased but didn’t install Diamond Kick Plates
Duraflare Standard Cut-Out Fender Flares
Rebuilt 2F Engine w/ 41,000 Miles on Rebuild
Clutch Replaced With Engine Rebuild
Webber 32/36 mm Carburetor
Man-A- Fre 6 into 1 header
New OEM Vacuum Advance Distributor
Poly Gas Tank
Bolt- On 2” Receiver Hitch
LT32X11.50 Radial White Letter Tires
Front Extended Shackles
Rear Add-A-Leaf
Rancho RS 5000 Shocks
Replaced All Poly Bushings
All New Charging System
New Brake Master Cylinder and Power Booster
New Clutch Master Cylinder
Rebuilt Rear Brake Wheel Cylinders
New Tie Rod Ends, Relay Rod Ends and Drag Link End
Rebuilt Center Arm
Man-A-Fre Steering Dampener
Custom Console
All New Door Weather Stripping
All New Hard top Gaskets
New After Market Rubber Floor Mat
Many New Emblems, Lenses and Trim Pieces
Toyota Chassis & Body Manual
Toyota 2F Engine Manual
Toyota Electrical Wiring Diagram
Some pics
Kayline Bikini Top
Poly Gas Tank
Rear Add-A-Leaf
Rebuilt Center Arm
Custom Console
Some pics
