I'm buttoning up a project where I'm putting an NP205 in my 40. Any ideas on how to adapt the speedo cable from the NP205 case to my factory FJ40 speedo?
mdjohnsen said:Should I talk to theose guys as well? I have a VDO speedo hooked up to my NP435. It's not working right.
.......The other option I researched was from Marlin Crawlers: 8" long speedometer extension cable. Fits all Toyota mechanical speedo application. Custom lengths, no problem. Just $1 per inch above the base price and size. The only problem was that I called twice and left two messages with no return call because I wanted to make sure that it would fit a 3/71 transfer case and 3/71 mechanical speedometer.
If that extension will splice between the instrument panel and the speedo cable, with the connection on the engine side of the firewall, it could make taking the instrument panel out easier. Mine is tight and it's a royal PITA trying to get my hand up behind the dash to disconnect/reconnect it.
It installs between the transfer case and existing cable...
These folks made me a speedo cable to work with my Atlas to the LC speedo head.
NEVADA SPEEDOMETER
878 MARIETTA WAY
SPARKS, NV 89431
Phone: 775-358-7422
Fax: 775-358-7488
Good luck!
-Steve
