Hey all,
I just recently got my new to me 1995 FJ80 on the road. I went ahead and changed the suspension to OME 2.5 inch lift, complete tune up, exhaust replaced, rebuilt front axle, new wheels and tires (33s on 17 inch wheels) and on and on.
After doing all the work, I went ahead and obtained a much needed alignment. I was hopefully that it would tighten up the slop I was feeling in the steering. To some extent, it definitely did improve significantly. Unfortunately there is still what I consider significant steering play.
I noticed that the steering column via the engine bay had a bunch of movement. It appears that as the column passes through the firewall, there is significant movement and as if some sort of bearing/bracket is missing.
Can anyone tell me if there should be such a bracket brace at the firewall? any pics?
the diagrams at part websites aren't clear in distinguishing.
also, any other ideas what may be contributing to the play in steering?
thank you
thank you
