LS1FJ40
did you check for integrity of the wiring harness at the EGR pipe ?
He has a 3FE. Isn't the wiring harness at the EGR pipe a 1FZ-FE issue?
If you are not blowing fuses it is not likely you have a short circuit but an intermittent open one. Bad ground or a hidden break at an old dried up connector. You don't need to drop the tank to check the fuel pump.No, I'm not blowing any fuses. Maybe the connector on top of the fuel pump is loose, but I don't want to drop the tank unless I have to.
I had it towed to a friend's shop, and after bouncing around on the flat bed, I went to turn the key and show him that it cranked without starting, and of course it started right up. So after bouncing and jostling around it started. One thing I did forget to mention is that every once in a while, if I hit a speed bump, the truck would lose RPMs, act like it was shutting off, recover and go back to normal. Something somewhere must be loose, chafed, not sure.
What Claudia was referring to is the wiring harness that runs across the EGR pipe on a 1FZ-FE motor. It has a tendency to burn through causing all sorts of woe and strife. This harness issue is not a concern on a 3FE motor.The 3FE runs the same with or without EGR so I wouldn't suspect that.
I asked these diagnostic questions earlier and never saw a response, so I will ask again.
"What is the condition of the distributor cap and rotor?
You need to verify spark during the next no-start condition. This is either fuel delivery related or ignition related. You need to eliminate 1 possibility."
The 3FE has an air flow meter (AFM) not a mass air flow sensor (MAF). While they are similar, they are not the same thing.Thanks for the info. It may be later this week until I can check everything; I already took one day of leave troubleshooting this s***, so I'll be trying to get to it in the afternoon.
I did clean the MAF a couple weeks ago. I replaced all the spark plugs, did an oil change, etc. The MAF was pretty dirty, but the flap seemed operational, and had good spring tension.
What do you mean by VAF, by the way?
Copy that. I'm just shooting from the hip here. I have had RIDICULOUS hard starts caused by the center button of the cap being worn down to a nub. We (I) sometimes ignore the most basic stuff and assume it's something more sinister by default.Jon, sorry I forgot to reply. The distributor and rotor seem to be in good condition. Not exactly sure what I'm looking for, to be honest, but physically, after pulling the wires and the cap, it looks good. Like I said, when it starts, it seems to run fine. What exactly should I be looking for?
Once again, sorry I didn't reply. I'm in the Air Force, and we had an airshow at my base this weekend, so I was dealing with that on top of dealing with the truck.
Don't get all dramaticI'll check again; like I said, airshow, + all my bad luck this weekend, I was a little distracted, and ready to drive the cruiser (if it started!) off a cliff.
I'll post results this afternoon
Your truck is 25 years old with what appears to be a questionable maintenance history. There's going to be some issues.
If your AFM was dirty your air filter is/was/has been shot. Between my '91 and '92 together they have well over a half million miles and the AFM was clean on both of them.
VAF
Vane Air Flow Sensor
http://www.aa1car.com/library/vaf_sensors.htm
The one in the FJ80's is licensed from Bosch. I guess Toyota calls it an AFM. Don't know for sure but I am guessing that just like the A/C compressor and some other parts, that you could pull one off of an old Mercedes, BMW, Audi and even certain american cars and make it work.
Did your fuel problems start before or after your PM session?
