I'm undertaking the gasket replacement on my intake and I need to remove the injector lines to do the job, my question is when I reinstall the injector lines do I tighten fully and then crank
motor, or do I need to have them opened a fraction to bleed the lines and then crank & tighten?
If I have cross over pipes on I cannot access to tighten, what is normal practice ? This my first attempt at play with injector line to remove and reinstall.
