Ya, Greg sorry I cluttered up your thread with pictures of my junk. I should know better.
As for the shades, think you are referring to @dirtEJohnson's truck. Mine was a large sunshade I purchased from Costco (multi-pack) and it fits just fine.
If the engine is bogging on the hills but not on the flats (when you push it) then I'm thinking it's a carburetor or fuel pump issue.
Yeah those needed to be replaced MANY MILES AGO..
The lower valance has 3 bolts on each side that bolt to each fender, one to each light bucket and one in the middle (all 10mm head). IIRC, you should be able to remove the valance without removing the bumper.
BEWARE THESE BOLTS BREAK VERY EASY!! USE CAUTION
J
Sweet thanks J (@reevesci)... any chance you know size/thread pitch of bolts? If the are 10mm thinking they are probably M10x1.25 (standard for lots of stuff).
Oh and here is a question for everyone... The Skyjackers can be mounted up or down, was planning on mounting with the tube down so that it would not hit anything but wondering if that will work? Anyone had any issues with this?
Also, cheap stock size shackles? Thinking of replacing mine as it looks like some of the threads are goobered. That is unless someone knows the thread pitch and size so I can run and grab a die to clean them up.
