Oh, And I later added a small powered sub that I put under the driver's seat. I wasn't looking for POUNDING bass, just enough to fill out the bottom end... it works great.
I have an older JVC Heavy Duty head unit (USB/Aux inputs), Kenwood Powered Sub and Blaupunkt component speakers. larger ones in the doors, tweeters velcro/double sided taped to the flat part of the dash at each far end pointing straight up. The crossovers are a little electronic box that splits the signal between the midranges in the doors and the tweeters. The powered sub has it's own control for frequency cut-off and amount of gain (boost).
I think this one:
http://www.jensenheavyduty.com/jens...-sirius-satellite-radio-ready-stereo-802.html
http://www.amazon.com/Kenwood-KSC-SW-KSC-SW1-Enclosed-Subwoofer/dp/B00092QM6A
An older version of these:
http://www.crutchfield.com/p_023MGCX130/Blaupunkt-Blue-Magic-CX-130.html?tp=106
How was the Alpine mounted. I would imagine the Jensen can be mounted similarly.
Pictures might help us to help you.
Just drill some holes in the bracket that line up with the Jensen holes!
