I have used it to power a cooler (can't actually call the Coleman powered cooler a fridge/freezer) but I would not use it for much more than that. I think it is only rated for 120 - 200 watts (or 1-1.75 amps)
I nearly burnt out the fuse when i plugged in my angle grinder. Tips of the fuse went brown. I had to pull it out clean it a bit and put it back in before it worked againUpdate. I plugged my Dremel into the back AC Port and left it in the ON position (carefully placed in confined box) then turned the vehicle on.
After a few seconds I heard the Dremel begin to hum and then took off full-speed. Then I took my 4 1/2" grinder and tried the same thing and zip. Too much amperage required?
I guess this port does not have enough juice to power more than my Dremel
It 100 Watt AC. Which for 110v circuit is just shy of an amp. So u can run a bright LED drop light and that is about it. Pretty useless really.I have used it to power a cooler (can't actually call the Coleman powered cooler a fridge/freezer) but I would not use it for much more than that. I think it is only rated for 120 - 200 watts (or 1-1.75 amps)
