Hi all
My mum is purchasing an HJ45 with 2H engine swap which she will eventually, if suitable, use to travel on the road. I'm keen to learn anything and everything I possibly can! It might be worth noting that I have no idea how many KM are on the 2H, nor does the guy I am buying it off, and the ODO only goes up to 99,999. Will post compression test results when I get a hold of her!
I inspected it and it appears to have a minor leak coming from the oil pan gasket. Should I replace it with a new gasket or would I get away with using something such as ultra black silicone like I did on my little Hyundai's pan? And while I've got the oil pan off is there anything else I should do under there - would it be a good idea to change the oil pump or do these last a long time?
Unsure of when the thermostat/radiator cap were last replaced so I will change them over with new OEM ones and will be recoring the radiator - anything I should know about this process apart from going to a reputable radiator shop?
Apart from basic maintenance is there anything else I should be taking into account before traveling/towing a 16-18ft caravan full time on the road? It will be driven quite a few hundred KM's before any long distance traveling so plenty of time for me to keep an eye on things, gather knowledge etc.
I will of course be slowly accumulating various spare parts - are there any parts in particular I should prioritize getting a hold of?
I'm keen to hear any and all advice regarding anything at all related to the these old cruisers, give me all you've got!
