Hey guys,
Doing a full frame off I was doing allot of research and after reading a very compelling technical article on vacuum in the vehicle, I am going to add a vacuum gauge. I know we have a vacuum pump on the back of the alternator. Does this and the vacuum reservoir on the frame support function of anything beyond the brakes?
Here is a chart that I found as a excellent reference from that article that clearly shows the vacuum gauge being used (mainly in petrol engines), but still good technical data.
CONDITION INDICATION
Readings are at idle unless otherwise stated. Gauge readings are in inches
1. Normal Steady at 15 to 21; Drops to 2, then rises to 25 when throttle pedal is rapidly depressed then released.
2. Intake leak Low steady reading less than 10
3. Head gasket leak Gauge floats between 5 and 19
4. Improper idle mixture floats slowly plus or minus 1 ½ to 2 ½ inches
5. Small spark gap or defective points slight float plus or minus 1 to 1½ inches
6. Late ignition timing Approx 2 inches below normal idle
7. Late valve timing 4 to 8 inches below normal idle
8. Worn valve guides Oscillates plus or minus 2
9. Weak valve springs Violent oscillation (plus or minus 5 inches) as rpm increases. Often steady at idle.
10. Sticking valves Normally steady, will intermittently flick downward about 4 inches
11. Leaky valve Regular drop about 2 inches
12. Burned or warped valve Regular, evenly spaced down-scale flick approx 4 inches
13. Worn rings/ diluted oil Drops to 0, then rises to approx 18 when throttle is rapidly depressed then released
14. Restricted exhaust system Normal when first started. Drops to 0 as rpm increases. May eventually rise to approx 18
Any consideration or suggestions from experience where the best place to insert the mechanical sensor is?
Here is the autometer gauge: http://www.autometer.com/vacuum-4231.html
For everyones FYI here the article on vacuum: http://www.ih8mud.com/tech/vacuum.php
