Hello all.
I replaced the speakers/sub in our 100 this past weekend, and thought I would do a brief write-up since I had some questions after reading other speaker threads.
I used the following speakers:
Front doors: Infiniti 6030CS
Rear doors: Infiniti 6032CF
Rear sub: Pyle PLPW6D
When I started, I wasn't sure what to expect since most of the threads I read were for '98-'02's.
The front and rear door speakers, were pretty easy to install. I am not going to cover the door panel removal because that has been well documented elsewhere.
Once you pull the door panel, you will likely find a blown speaker like I did.
Removal is straight forward, unplug the plug and remove the 3 gold screws that secure the speaker/bracket to the door. Once you have the entire assembly out of the truck, remove the four screws securing the speaker to the plastic bracket.
Then pry the speaker away from the plastic. There is a double-sided adhesive holding them together that just requires a little steady force to split the two pieces.
Once you have the speaker and housing apart, you will need to unplug the wiring harness connecting them. This will leave you with 3 pieces.
