- Thread starter
- #41
re_guderian - can't get an OEM spring to check, but my OME spring I could measure when I lift the car up. The shackle pin to pin distance seems to be the same on OEM and OME.
Jim - that's the problem, nobody here can tell you what bolts they sell, it's just gambling... so I better stay out of this and bought 4140 steel from a trustworthy supplier.
I will try to do solution 2 with 14mm shoulder, also for the front pins. Will drill out the rear shackle brackets and also the front pin bracket to 14mm and lock the pin to the brackets with the nut before installing. Should then be the same as the stock setup that screwed into the bracket. On the radius of the undercut (that will be AFTER the shaft so no shear force there!) I am aware and will tell the machine guy to take care of!
Looks like it's also the same pin on the front... just the brackets are 6mm and the rear ones are 8mm, but otherwise the same pins as much as I can tell. Will replace the front pins too, they also showed lots of surface wear when I replaced the bushings in Quito.
Thanks guys for your inputs!
