- Thread starter
- #21
I've now ordered all the engine bits. By the time it's said and done, I'll have about 1k in the motor - and it will be new (including new lifters since I suspect the old ones were collapsed).
a breath of fresh air thank you.... on pirate I got into a huge argument over my plans on keeping a short wheelbase. to the point that this morning I basically told them **off. You'd think I killed Santa Claus by beating him with the Easter bunny when I said my wb would be 96" - the horrors of that suggestion... omg.I just throwing this out there. Have you considered about an 1 or 1 1/2" body lift so you can raise the t/case up a litte. I just went thru this w/a j**p yj, stk 4.0, AX15, 241/dana300 doubler T/case, sprung under. We moved the engine forward & up an inch & the rearend went back 2 1/2". We tilted the engine & driveline angle alittle more than stk, & clocked the 300 so it's flat & upside down. It has a short & steep angle double cardon D/S in the rear, but it works.
