- Thread starter
- #41
Do you think the mvci driver is loading? There is a LED in the unit's plug that should illuminate and you should see an x-horse mini icon in the bottom bar of XP, click that and see if the driver is responding. You've got you ignition on when you try and connect? The tundra.net site has a wealth of info and dedicated TechStream threads, you might find the answer there.It was not able to connect to the car. "No connection".
I try to do the MVCI device info and it shows as no connection, then I did the cable test under help menu and again all showed up as red as none of the pins were connected.
I replaced the required file as instructed into YouTube video. Everything sets up as it's supposed to except when I hit connect a vehicle, it shows as "no connection".
