well i got stuck 40 ft into swamp with nothing to pull from and the front mounted winch (8274) was "under water". it was here i realized i need a portable Winch that i can move to either the front or rear of the rig depending on the foreseen need. can anyone recommend a winch that is strong enough to be useable on an (empty) 80 series and still light enough to move front or rear as needed.. say around 75 lbs> my 8274 with a synthetic line is around 120lbs debilitatingly heavy.
