145K.....Was running very strong and smooth with a long crank after warm up..........
Then I tried to fix the long crank and the truck is to the point where I can't even get it out of the garage now.
I've started a lot of threads trying to figure this out, so I apologize in advance for that. I'm going to compile everything here and hopefully get a solid lead to go on, I'm running out of ideas and not at the point where I'm ready to just start changing parts.
The truck fires up and idles low while stumbling, it doesn't have enough power to get itself down the road at all.
I've changed vacuum lines that were fitting loosely over their connections
new NGK v-power spark plugs as listed in the manual
new Fram fuel filter
carefully sanded contacts on fuel relay
cleaned MAF sensor with special cleaner
checked air intake boot for cracks
rebuilt stock charcoal canister with new charcoal and cleaned check valves
Things to note:
I'm not getting vacuum at the purge valve hose going to canister even at 3000rpm on a warm engine
Pressure still builds in the gas tank
black fuel and particles came out of filter when I blew it out with air
When I hit the muffler with a hammer I can hear debris in the bottom of it
There is a hissing sound coming from the vacuum port leading to the brake booster/EGR area. But when I spray starting fluid there it makes no difference in the idle.
The ground plug going from intake manifold to body ground and back to coil has been unplugged since I bought the truck, the morning I plugged it in, the truck started running as it does now. I checked voltage at the ground plug coming off of the intake manifold and it showed .20 volts with the plug unplugged, it showed 0 volts with the plug plugged in. Could I have burned the coil up by grounding it to .20 volts coming off the intake manifold? The plugs were separated from the PO and not taped up or anything.
I've gotten it running much better along this journey, and every time I disconnect the battery to clear the codes, it runs worse and worse.
First code was P0170
Next code was P0125
current codes: P0300, P0302, P0303, P0304, P0305, P0306
Any help would be greatly appreciated.
Things to note:
Next code was P0125
