So I flushed my cooling system and low and behold, it started a leak at the water pump. I pulled everything out and the leak appeared to be coming from the disintegrated paper gasket.
The new gasket that came in was metal. I scraped the old gasket and replaced. It appears to be leaking from the same place but it is hard to tell. Should I have not used this gasket or is there somewhere else it could be leaking from. I could really use some help. I am having to rely on my motorcycle which sucks when ur trying to remodel a house and cant get to the hardware store to pick up supplies.
Also build date is OCT 88. I had an earlier thread where I was looking for info on clutch and radiator fans. My Japanese RH cruiser had the fans of a different region model, is it possible the pump was different as well and needed a different gasket?
