Ok, my first mod to the 200!! Part of my plans for this rig include a dual battery setup. Unfortunately, it doesn't look like anyone makes a kit for a group 31 in the stock location. So I did it from scratch. I fabbed the brackets from 1/8" aluminum based on some ideas I got from the interweb and mostly from 100 series group 31 brackets. All in all. it was pretty straightforward. The 31 fits without issue, so the only work was the brackets. I used some group 31 stud adapters so I could use the terminals on the battery closest to the edge. Next step: add the second battery, which will be my starting battery and isolate the two. I decided to go with the two Die Hard Marine Batteries because I wanted to go AGM and they're just rebadged Odysseys but quite a bit less than if they sport the Odyssey label... So, here are the pics:
Brackets
Nut-Serts
Tray in
Battery in
Brackets
Nut-Serts
Tray in
Battery in
