I am about to do a power steering conversion on my Australian bj40.
I am running a 13b diesel which has the "built in" power steering pump, gear driven from timing gears.
My question is mainly about the steering box. I have a 60 series box and pitman arm I bought for the conversion, however I also have an 80 series box and pitman arm as a spare from my daily driver,
Which box would you recommend using and why?
Which box would be better matched to the power steering pump?
I will be running 35" muddies - do you recommend an oil cooler? I'm assuming if I put one in, it should go in the high pressure line?
