The diff locks use a dog clutch that relies on different axle shaft rotational speeds to align the teeth. In order to get them to line up faster you can drive in an arc.
My rear seats have been folded up since I bought the Cruiser which of course greatly expands the storage capacity.
My 33" tires have a noticeable impact on acceleration. ( I believe 29" was stock )
You will find that 3rd gear is your friend. : )
My oil pressure (new 24v OEM sender) is about like that at hot idle.
You can get a new radio bezel for about 15 bucks by the way.
You can also replace the sending unit. I bought it from the local dealer. CDan has a thread on replacing it. Did mine this weekend. Took out the air box for access. You'll feel better about your oil pressure.
Good luck!
Peter
One option for the antennae....... Your brush bar.
There was a conflict with the factory antennae and the snorkel so it was moved to the brush bar. It is about 5 feet tall and in addition to receiving numerous radio stations it discourages low flying birds and drones.Figured that was a VHF or CB, so far the 12" that is left can get all the local stations so its getting me by.
