A little background...
Just installed a used points dizzy in my 77' FJ40. Bran new points and condenser. Points gapped correctly, plugs gapped correctly. Continuity in all plug wires and rotor. (0 ohms). Engine block grounded. I am getting 12 VDC at the ignition wire. I had the coil tested and it is good. When I hook the ignition wire up to + and distributor wire to - I get nothing on the multimeter. Also no spark when I crank it over. This same dizzy worked in another Fj40, so I am not sure what is going on.
More background.... I initially hooked the wires up backwards (ignition to - and dizzy wire to +) and I think I fried the points/condenser which is why I replaced.
Where should I go from here?
...via IH8MUD app
