Yes, I know I don't need it but....
Putting a rear third in the front and wondering if I can leave the thrust block on the pinion shaft? My thinking is that this would allow the axle shafts to not drop into the differential if I don't put inner birf circlips on (or outer clips at the hub, too?). This would effectively accomplish the same result as a Martack, right?
I'm going to go try it and see how it works, I'll post up a result.
