I have a td04l 13t on my 3b and was wandering if something like a vf34 or td05 16g may provide little more topend power? will these be alot more laggy?
i have seen that you can get a 19t compressor housing upgrades and want to know what a bigger compressor wheel achieves? If i keep the exhaust turbine the same size wont this just be my limiting factor even with the bigger compressor housing?
http://www.ebay.com.au/itm/Turbo-Co..._Parts_Accessories&hash=item3f32c48899&_uhb=1
Thanks!
A TD05 will kill off all your low end boost. The TD04HL turbine is the next step bigger than your current. A bigger OD compressor wheel has higher tip speed to produce more boost at lower rpm. The 19T is overkill for a 3B but it is an efficient wheel with a good surge margin so it will still work well.
Top end power lacking is I'm afraid more about the 3B than the turbo.
A TD04HL-19T on a 4BD1T should be able to hit ~180kw at ~3200rpm (30psi). The HE221 is the next step above the 19T and is closely related. It should be able to break 200kw by 4000rpm.
