Has anyone added an amplifier to a 02 Land Cruiser with factory Nav bypassing and removing the Stereo Component Amplifier? I'm noticing on the 2004 EWD that the Front Left speakers line out run to the Nav ECU first out of the factory nab which allows the Nav to pass voice instructions out. Obviously if I cut the line before the Factory Amp, the Nav would not be able to use the output amp signal?
My desire would be to remove the factory amp and get pure Head signal to the Line outs converter. Based on Page 112 of the EWD, It seems like I may have to use already amplified outputs though: Front Right/Rear Left/Right Rear from the factory amp, then use the Front Left output after N2, the Navigation FCU.
I really appreciate the help, in advance. For the curious, I'm installing Memphis line out converter, 4-channel special use amp, 1-channel special use mono amp and Kicker component and 2-way speakers and Kicker 10" box sub. These special amps are only 5.4"x4.4"x1.5". I'll be glad to post some install pics and a system review. Great people at Pro Audio in Austin are both inventory and service maniacs.
