curtislow
Third fj40
I'm in the middle of doing my front knuckles,calipers, tie rod ends and brakes. I just put my tie rod end on and put the tires back on checking for clearance and any other issues. My question is , is there supposed to be any side to side movement with the truck up on stands and grasping the tire in the 3 o'clock and nine o'clock position?
When I set the wheel bearings I tightened them to 49 Lbs spun the tire, loosened, repeated and then torqued to 21 lbs from some where I read to do this.Should they be tighter? Thanks. I did do a guick search but hoped someone might chime in and give me an answer,I'm no mechanic I just play one in my garage.
