Thanks Scrapdadday-I might invest in an 80 series master as that seems to be a popular choice on rebuilds. (Hopefully my local toyota place has one.) Appreciate it!Sounds like to me, the rear circuit isn't working right in the master. I had a brand new clutch master from Toyota, not pump up, couldn't purge the air out. I bought another and worked fine.
Holy smokes that is a great article from what I quickly scanned so far. I think just what I have been looking for.
I did not see much on the 40 series parts going into the 55's... Interesting idea though. However i really want to update to more current parts and I honestly did not think it would be such an issue. Surprising as the upgrade I did to the front axle went really well.Just curious why you didn't just swap in newer 40 series parts or whole axles? Front discs, rear drums, Booster from a 40... seems like the simple solution.
Thanks Capt... and good to know I still have the option to go disc with the model year of my rig. Appreciate the detailed reply!!OK Moose, in reference to my disk conversion. I'm a half ass but do it right mechanic. After installing the disks I got tired of screwing around and took it to a shop where the pros bled it tout suite! Yes, you are chasing an air bubble or bubbles in the line....
The rear is just a simple 3 way T not a fancy valve....
Nothing on a residual valve. I have not heard of that too much so will look into it. A quick scan showed only 1/8 fittings available. (I'm running 3/16 hard line with 10mm and 3/8 bubble flair fittings)You said you have a proportioning valve, do you have a residual valve to maintain 10# of pressure on the rear brakes?
I'm in the process of doing it too.
As for front only.....I'd venture to guess 90% of disc front 40's and 60's on the road have crappy or no rear brakes. Mine don't and have not worked on my 60 for the last 5000 miles.
I'm like you, I will screw with it for just so long and I'll cap that rear end off and rock on.
If you block off the rear, why go thru all the trouble of setting up a dual system when you will still end up with a single brake system. that's how people die. you hit someone and they find out you blocked off 1/2 your brake system, you'll be hosed.
there are 2 things on any rig that need to function properly: steering and brakes.
rant off.
1: did you bench bleed the master before installing? I found this to help immensely.
2: you can make a pressure bleeder pretty easy: The DIY $20 brake bleeder
3: Don't bother bleeding the rears until the brake shoes are adjusted properly... The way the Toyota dual piston cylinders work will allow a lot of air to be trapped and un-bleedable if the pistons are even slightly extended before shoe to drum contact. adjusting the brakes helps mitigate this problem.
4: sometimes big loops of brake tube can trap fluid with standard bleeding. pressure bleeding quickly pushes enough volume of fluid and helps prevent the bubbles from settling in the high spots in the loop.
