malteserunner
Dr Evil
No. In 333 kilometers you will though
No. In 333 miles you will though
kilometerstone?
You going to the Waianae side or northshore side?I'm going to kaena point on sunday...
Hit this milestone.
No confusion....I'm Mexican, so that's what I call them.
All those miles And your D still works? Wow
529s & 35s...Hmm that would be like 3,500 rpm @ 60 mphDon't you dare!!! Regear 5.29 for 35" or 37" but works best with 35" tires and you can actually tow!
I agree with breather comment, disagree with Slinky weight capacity comment.Breather lines is not a must but it is good to have just in case you get the slinky springs that have no weight capacity! Also gets rid of the 20+ year old breather that might be working or not be working!
I AgreeSway bar drop bracket is also good to have to bring everything back to stock specs.
I Agree
My D is still goin' hard
Science.
That's to fancy... I just used a long stretch of .25" vacuum hose with a cheap in line fuel filter then rolled in a full 540° turn at the top to prevent water entry.ARB breather kit then?
@jtwopark
Where did you hear that Slinkys have no load capacity? It's definitely not accurate. I have a heavy truck with lots of gear, a RTT, armor and I pull a trailer with another RTT and full of gear. The Slinkys handle the load way better than my OME J's ever did.
