An unmolested intake. This is the underside and one corner needs to be ground down to eliminate the interference with the 3FE exhaust manifold. The white material in the holes is dirt dobber mud .
The is the manifold I've worked over and you can see the corner where material has been removed. A fair amount has be taken off.
Before actually mounting on the 2F I'm planning on dry mounting the manifolds on a head to check final clearances.
