formerly owned by another forum member, this beauty got new tires, polish, and wax today. I've been waiting and searching years for this one.
Much of it has to do with my OCD.Looks great! What specifically took you so long to find one? Mine is mostly price related, and also don't want black exterior.
Nice - first order of business is to polish and seal/wax the lights, and upgrade the lows to a quality LED kit. Big improvement over the halogens in looks and performance.
Can you describe these items in more detail ?
@TexasHusker
@Dan Higgins
If you look closely, you'll see UV degradation on the outer plastic which is very common although yours is in decent condition. Though, I have seen many times where you can take a slightly cloudy light and make it crystal clear. Usually, this can be polished off either by hand or with a rotary buffer - can use a buffing pad and a product such as PlastX or Meguiars 105/205 to improve the clarity, and then you seal the lights with either clear vinyl, polish, or wax.
The standard halogens run very hot, have only average output, and can be easily replaced with a plug and play kit to give a huge improvement in the appearance and light output. There are a number of kits, I run the Opt7 (which is the top seller of these on Amazon) which is a great product. No affiliation with them, it's just a great product with CREE emitters and excellent intensity.
Check out some of the photos here: https://www.amazon.com/dp/B00VNBDWPK/
Ok so on the headlights, you are changing out the halogens for LEDs? How do you do that? Sorry for the ignorant reply - just not familiar with it. How do you ensure that the LEDs will fit correctly ?
